February 8, 2021 at 10:29 am
scholar
SubscriberHello everyone,
I am getting a "subscript requires array or pointer type" error in the red lines of the code attached.
Could anyone suggest how to resolve this error?
February 8, 2021 at 10:49 amRob
Ansys EmployeeCompare with the manual entry, https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v211/en/flu_udf/flu_udf_sec_define_vr_rate.html I suspect INDEX_PHASE_C0 and INDEX_SPECIES_C0 aren't recognised. nDefining values as zero and then calculating them isn't necessary either. We'd only tend to set a value after a calculation using an IF statement if the calculation returns an invalid number: typically to prevent a rate or property being less than zero. nViewing 1 reply thread- You must be logged in to reply to this topic.
5364
3363
2471
1310
1018
