April 20, 2022 at 4:01 am
Zacyboy
SubscriberI want to untick the Enable constraint based sketching in advance options, but I untick it and press ok, then close spaceclaim. After reoping spaceclaim, it is ticked and didn't save my options. Is there a certain way to restart the spaceclaim?
April 20, 2022 at 6:23 amKeyur Kanade
Ansys EmployeeExit all SpaceCLaim sessions open. If that does not work please try restarting your system once.
Please go through help manual for more details
Regards Keyur
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2666
2120
1349
1132
461
