April 28, 2022 at 12:31 pm
Eldor
SubscriberHello, I have a stupid question for which I didn't find any answer (because I don't know how to phrase it): if I solved an analysis, then made a change (for example adding a force or changing the mesh) and then cancel this change I still need to solve again the model. How can I tell the program to retrieve the previous results?
Thanks
April 28, 2022 at 2:06 pmChandra Sekaran
Ansys EmployeeIf you did not do 'Clear all generated data' then possibly the results file is still available and you can try to reload it.
Go to 'Solution' --> right mouse click--> open solver files directory. Check if there is a results file (file.rst if structural, file.rth if thermal)
Click on Solution, Open the solution tab--> read results file as shown below. Read the file.rst.
April 28, 2022 at 3:15 pmEldor
SubscriberThank you it works!
Viewing 2 reply threads- The topic ‘How to retrieve solved simulation when you made a change and cancelled it’ is closed to new replies.
Trending discussions- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3153
1680
1470
