Discovery Import
Discovery Import
How to rotate a section plane on ANSYS Discovery 2021R1
    • TNoguchi
      Let'me know how to rotate a section plane on new GUI of ANSYS Discovery.
      I want to see the section plane mapping from results.
      I can see the arc arrows to rotate a section plane on previous GUI.
      I can't display the arrows on new GUI.
    • Naresh Patre
      Hello TNoguchi
      If you enable the Cut Plane option from Results Arc, then select the cut plane, the Move handle with arrows appear for orienting the plane as required. See below snapshot. Is this what you are looking for?
