Ansys Products
Ansys Products
How to run ansys fluent on supercomputers remotely
    • sakwaboa
      Can somebody point me to a tutorial for running Ansys Fluent on Supercomputers remotely (ssh)?
      There's a section in the User's Guide showing all the scripts/journals etc to run in batch and remotely. There won't be a tutorial as it's just a case of putting the command line into the system.
    • sakwaboa
      • I'm reading chapter 34 in the user's guide (version 18.2). I hope that is the correct section.
    • tsiriaks
      Yes, that should be it for v18.2
    • JosiSandoval
      Hi
      I'm trying to do the same in Ansys mechanical (static structural). I'm looking at the Ansys mechanical user's guide, but I haven't found a chapter related to running Ansys remotely. I also checked the Remote Solve Manager user's guide, but I think that is not what I'm looking for.
      Which user's guide should I look at? I'm using Ansys 19.4
      I'm trying to run Ansys remotely using NoMachine connection
      Thanks
Viewing 4 reply threads
