October 24, 2018 at 7:35 pm
pawar002
SubscriberHello,
I want to run my fluent case on remote HPC cluster system. I am using windos 10.
Thanks
October 25, 2018 at 1:35 am
October 25, 2018 at 2:54 pm
pawar002
SubscriberHi Kremella,
Actually, ANSYS 19.0 is installed on Linux based cluster and I have ssh credentials to connect with it. I want to know that how to write a batch script to submit the fluent.cas and fluent.dat file on the cluster to run the case from windows 10. I am using ANSYS Academic Research Licence. I also want to know that how many nodes I can use for parallel processing.
Thank you.
October 25, 2018 at 3:50 pm
Ansys EmployeeBatch scripts are covered in Chapter 4 of the Getting Started Manual, but the exact method will also depend on how your cluster is set up: IT may need to advise on that. Re the number of cores it'll come down to what is available on the hardware and how many parallel licences you have access to.
October 27, 2018 at 2:48 am
October 27, 2018 at 9:54 am
DrAmine
Ansys EmployeeCheck with your IT if the server is down and let them check server and client diagnostics.
October 29, 2018 at 9:52 am
seeta gunti
Ansys EmployeeHi
Error message is saying that could not connect to any license server. I guess this could be an issue with the server. Please check with your IT team about the license is upgraded in the server or not and also on server issues.
Seeta
October 29, 2018 at 5:10 pm
pawar002
SubscriberHello,
I am trying to run the case but now i getting this error:
/home/ansys_inc/v190/fluent/fluent19.0.0/bin/fluent -r19.0.0 3ddp -g -cnf=/var/spool/torque/aux//1521.umkc-hpc -t32 -i 3D_HP.jou
/home/ansys_inc/v190/fluent/fluent19.0.0/cortex/lnamd64/cortex.19.0.0 -f fluent -g -i 3D_HP.jou (fluent "3ddp -pmpi-auto-selected -host -r19.0.0 -t32 -mpi=ibmmpi -cnf=/var/spool/torque/aux//1521.umkc-hpc -path/home/ansys_inc/v190/fluent -ssh")
/home/ansys_inc/v190/fluent/fluent19.0.0/bin/fluent -r19.0.0 3ddp -pmpi-auto-selected -host -t32 -mpi=ibmmpi -cnf=/var/spool/torque/aux//1521.umkc-hpc -path/home/ansys_inc/v190/fluent -ssh -cx node002:43023
3668
Starting /home/ansys_inc/v190/fluent/fluent19.0.0/lnamd64/3ddp_host/fluent.19.0.0 host -cx node002:43023
3668 "(list (rpsetvar (QUOTE parallel/function) "fluent 3ddp -flux -node -r19.0.0 -t32 -pmpi-auto-selected -mpi=ibmmpi -cnf=/var/spool/torque/aux//1521.umkc-hpc -ssh") (rpsetvar (QUOTE parallel/rhost) "") (rpsetvar (QUOTE parallel/ruser) "") (rpsetvar (QUOTE parallel/nprocs_string) "32") (rpsetvar (QUOTE parallel/auto-spawn?) #t) (rpsetvar (QUOTE parallel/trace-level) 0) (rpsetvar (QUOTE parallel/remote-shell) 1) (rpsetvar (QUOTE parallel/path) "/home/ansys_inc/v190/fluent") (rpsetvar (QUOTE parallel/hostsfile) "/var/spool/torque/aux//1521.umkc-hpc") )"
Welcome to ANSYS Fluent Release 19.0
Copyright 1987-2017 ANSYS, Inc. All Rights Reserved.
Unauthorized use, distribution or duplication is prohibited.
This product is subject to U.S. laws governing export and re-export.
For full Legal Notice, see documentation.
Build Time: Dec 18 2017 15:05:43 EST Build Id: 10138
ANSYS LICENSE MANAGER ERROR:Could not connect to any license server.
The server is down or is not responsive.
ANSYSLI_SERVERS: 2325@KC-ISSS-LS06
FLEXlm Servers: 27005@KC-ISSS-LS06
I have one question, I have set up my case in windows ANSYS 17.2. And in the cluster (Linux OS), it is ANSYS 19.0 (Linux version). is this error because of different OS version or what?
October 29, 2018 at 7:07 pm
DrAmine
Ansys EmployeeThe error is due to licensing issue. Error message is saying that could not connect to any license server. I guess this could be an issue with the server. Please check with your IT team about the license is upgraded in the server or not and also on server issues.
October 30, 2018 at 8:00 pm
pawar002
Subscriberwith five academic research licence how many CPUs I can use?
Build Time: Dec 18 2017 15:05:42 EST Build Id: 10138
This is an academic version of ANSYS FLUENT. Usage of this product
license is limited to the terms and conditions specified in your ANSYS
license form, additional terms section.
Host spawning Node 0 on machine "node012" (unix).
/home/ansys_inc/v190/fluent/fluent19.0.0/bin/fluent -r19.0.0 2ddp -flux -node -t32 -pmpi-auto-selected -mpi=ibmmpi -cnf=/var/spool/torque/aux//1545.umkc-hpc -ssh -mport 172.16.0.12:172.16.0.129139:0
Starting /home/ansys_inc/v190/fluent/fluent19.0.0/multiport/mpi/lnamd64/ibmmpi/bin/mpirun -e MPI_IBV_NO_FORK_SAFE=1 -e MPI_USE_MALLOPT_MMAP_MAX=0 -f /tmp/fluent-appfile.vrp1.110269
Unable to spawn node: license not available.
ANSYS LICENSE MANAGER ERROR: Not enough ANSYS Research Associate Parallel licenses 32/16.
October 30, 2018 at 8:30 pm
DrAmine
Ansys EmployeeSo that means your initial problem is resolved. Please mark then this topic accordingly.
A single academic license can run up to 16 CPU cores, or alternatively up to 8 GPU cards. So in order to run on 32 CPU cores you require the academic license task (solver + inbuilt 16 CPU cores) + 16 ANSYS Academic HPC Associate Licences.
October 31, 2018 at 4:51 pm
pawar002
SubscriberHello abenhadj,
So if, I have 4 academic license can i use 4*16 = 64 CPUs?
Thank you.
October 31, 2018 at 5:26 pm
DrAmine
Ansys EmployeeNo. You need academic HPC licences.
February 21, 2020 at 5:32 pm
cs437
SubscriberHi,
I run both HPC Server and local computer; however, the scaled residuals are different like one or two orders of magnitude. On my local computer, which is very slow, reached 10^-3 or 10&-4 while just 10^-1 is on HPC at the same iteration. Is this possible?
February 21, 2020 at 6:06 pm
DrAmine
Ansys EmployeeOpen new thread please and yes that can be possible if using different partitions versions and not really converged.
2616
2098
1323
1108
461
