How to run multiple design points in parallel using optiSlang DoE?
    • agarwa20
      I am running an optimization using Ansys optiSlang in Workbench. For the sensitivity analysis step I am creating a design of experiments using a sampling scheme and a number of samples. I am unable to run multiple design points in parallel for the DoE. Below is the procedure I followed:
      Step 1: Select properties for the DoE.
      Step 2: Select simultaneous execution mode and choose number of design points to be sent parallely.
      Step 3: Change update option from Foreground to Remote Solve Manager
      Step 4: Checking the simulation, while running shows that the design points are being sent in parallel
      Step 5: All resulting designs obtained are failed designs even though the for single design point at a time all succeeded.
