How to safely change the name of the file
    • Galaxy
      I didn't see any option to rename the file and would rename the file in File Explorer damage it?
    • Sampat Kumar
      Hi Jintan,
       Do you want to rename the file "ME 3263: Cantilever Beam Frequency Vibration-WB"?If yes, then you need to save it with a new name in the system by clicking on the file and using save as.
      If you want to change the name of the analysis in the project schematic, then you can click on the Rename option, as I have highlighted in the image. If this is not what you are asking, then please clarify it in the details.
    • Galaxy
      The file name "ME 3263......" was what I wanted to save. If I use save as, will it create another exact same file? Or so, is there a simple method to rename like to rename the analysis?
      • Aniket
        save as should create a copy of exact same file. Do pay attention to paths of imported files, if any.
        -Aniket
        Forum Rules & Guidelines
