July 3, 2020 at 7:58 am
Nicolo
SubscriberHi
Currently I am working on a VOF two phase flow model in ANSYS and it faces the Floating Point execution Error. But I am trying to read the pressure drop between inlet and outlet before it diverges (basically at a time step before the errore).
Does anyone know how to do it (or would it give wrong info)?
July 3, 2020 at 8:38 am
Forum ModeratorIs the solution diverging or is something else happening. Re getting pressure data look at the surface reports, you'll want area average. However until we we (you) understand why the solver is failing the data may or may not be any good.
- A solver pivot warning or error has been detected
8804
4658
3151
1680
1470
