February 9, 2022 at 6:21 am
matus
SubscriberI am working on a simple (2D) plane geometry. The simulation involves both thermal and structural analysis.
There is convection heat transfer is taking place on one side of the plane for 10sec. I wanted to see the structural deformation corresponding to the temperature load at different time intervals.
Unfortunately, I cant see the deformation at different time intervals, instead only see the deformation at the end of time.
February 9, 2022 at 3:09 pmAshish Khemka
Forum Moderator
Please see if the following videos help:
ANSYS Coupled Transient heat and Structural Analysis of Leaser Cut - Bing video
Coupled Thermal - structural analysis - ANSYS Tutorial - YouTube
Regards Ashish Khemka
February 10, 2022 at 3:39 ammatus
SubscriberThank you.
- A solver pivot warning or error has been detected
8786
4658
3151
1680
1468
