how to select a face of a beam
    • fa-ri
      hello
      I need shear force and bending moment diagrams for a beam.
      the load is a function of two variables and acts on the surface.
      I create an airfoil cross-section beam in the design modeler. but can't select face to apply the force.
    • peteroznewman
      You can only apply forces to the beam elements that are on the line body. The surface you can see is just for visualization of orientation of the beam.
    • fa-ri
      Thank you for your reply.
      I have used the solid form and my problem whit load distribution solved. but have a new problem to use beam tools. I can not select the body in geometry.
