How to select a specific part of domain in CFD-post?
    • hamda
      As you see in the following picture, there are several spheres and I want to select one of them to investigate Temperature, velocity and pressure  distributions. How can to select this specific sphere in CFD-post?
    • Keyur Kanade
      you can use insert - location - isoclip.
      please see image below where wall is separated usinng x coordinate values.
    • Keyur Kanade
      if this helps you, please mark this as 'is solution' to help others on forum.
    • hamda
      Thank you but could you upload the picture with higher quality since  I can't see details section well.
Viewing 3 reply threads
