August 12, 2023 at 8:37 am
haibin wu
SubscriberI have encountered a problem now. I have two body A and B, and for some reason I cannot merge them or delete them. There is now a blue face in A body and a yellow face in B body. These two faces actually overlap, but because they belong to different body, I cannot select the blue minus yellow circular face. What elegant way can I choose the circular face? This will be of great help to my future step of Wall named. Thank you very much and I look forward to your reply!!!
August 12, 2023 at 1:54 pm
SubscriberIn SpaceClaim, on the Prepare tab, use the Imprint button. That will split the blue face on body A into two faces.
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7808
4508
2979
1453
1322
