Ansys Products
Ansys Products
How to select research or teaching license features?
    • dyat
      Prior to Ansys version 2021, it was possible to use the "anslic_admin" program to select the preferred order in which licenses were checked out (so a user could choose to use Academic Research instead of Academic Teaching licenses, for example.)
      But, the anslic_admin is no longer used in recent Ansys releases.  How can a user select whether teaching or research licenses will be used if the license server includes both types of license features?
    • George Karnos
      Open Workbench and then Mechanical.
      Go to: File->Licensing
      Order the licenses there.
    • dyat
      Thanks for your reply, but I don't understand it.  I start Workbench on linux using "runwb2' but I don't see any item named "Licensing" in the File menu.
      Do you mean to start DesignModeler when you wrote "open Mechanical"?  I don't see a Licensing item in the file menu there either.
      What about if somebody wants to use fluent or Electronics Desktop?  How can they indicate they want to use research or teaching licenses for those applications?
