March 11, 2022 at 4:27 am
aminahonicholas
SubscriberHello,
I'm trying to set the absolute permeability of a rock in my model, but I can't find it in the engineering data section. Please, does anyone have an idea on how I could set absolute permeability in ANSYS Structural model?
Thanks
Efenwengbe
March 16, 2022 at 9:00 pmBill Bulat
Ansys EmployeeI might be missing something but as far as I can tell, neither diffusion, coupled structural-diffusion, nor porous media flow analyses are natively supported in Workbench. It appears that these are the types of analyses for which permeability would be defined. For now, I presume you are setting up your analysis using APDL command objects. Continuing under this assumption, the permeability material property would also have to be defined with a command object (please correct me if I'm wrong about this).
For a pure diffusion calculation, or coupled structural-diffusion analysis used PLANE222/PLANE223/SOLID225/SOLID226/SOLID227 element types, I think leaving Csat (the saturation concentration) undefined causes the MAPDL solver to take the permeability value(s) that you have defined to be absolute rather than relative.
At present, I don't see a way to define absolute permeability for porous media flow analyses.
--Bill
March 17, 2022 at 10:27 amaminahonicholas
SubscriberThanks Bill for your contribution. I am not directly using a command prompt to setup the simulation. I set up the engineering properties, develop a geometry, setup the simulation (model) and solve the problem. Does anyone follow similar process and have managed to setup permeability in the engineering properties section of the simulation?
Nicholas
2630
2104
1327
1110
461
