August 15, 2019 at 2:02 pm
Hshay
SubscriberGreetings everyone! I am a graduate student who majors in LS-DYNA, I was simulating the cable(also as wire, web, rope) with APDL recently, I set up the model with link167 and elastic material, but I found when the rigid ball hit the web, the web just can't stop vibrating, I think there should be damp somewhere or should I change link167 to link180?can you guys tell me how to adjust it and how to use hyperelastic material? Thank you very much!!!
August 15, 2019 at 2:12 pm
jj77
SubscriberNot sure what 167 (explict perhaps).
If you are using APDL nonlinear transient dynamic (implicit)
You need to add damping in form of Rayleigh damp.:
E.g. (You need to find the correct values),
ALPHAD,0.1
BETAD,0.001
Just as an example
For explicit see how damping is defined in LSDYNA say ( I do not have any exp. in Ansys - LS DYNA)
(e.g., EDDAMP command )
There is an example about this command and damping in appendix D of the ANSYS LS-Dyna User Guide in Ansys help.
Perhaps this is of use also
or in MP, BETD or MP,ALPD command
August 16, 2019 at 2:08 am
Hshay
SubscriberThank you so much for your reply, I am working on it just as what you say, thank you!!!
2120
1347
1118
461
