How to set DPM boundary condition for “interface” in Fluent?
    • jianan.zhao
      Hi everyone,
      I have trouble with choosing the correct boundary condition for DPM simulation in Fluent. There are two domains: room domain and human airway domain as shown in figures. The interface between those two domains is named "mouth-inlet", which is set as velocity inlet. Particles are injected at the table in room domain. I would like to see how many particles are transported into human airway.
      What type of boundary condition should be imposed at the "mouth-inlet" to let particles be tracked continuously in both room and airway domains? Can I use UDF to impose an interior boundary condition for the mouth-inlet? I would very much like to know how to write interior boundary condition UDF for DPM simulation. I really appreciate any help.             -- Jianan
    • Keyur Kanade
      Can you please try Post processing --> model specific --> Discrete phase --> Sample.
      Sampling of DPM particles can be used to get the information of particles passing through the boundary (passing position and particle velocity and particle size, etc.).
      Keyur
    • jianan.zhao
      Hi Keyur,
      Thank you for reply. I will try your method. By the way, do I need to use UDF also? Thank you.
      Jianan
    • DrAmine
      For general purpose sampling you do not require any UDF.
      A.
Viewing 3 reply threads
