Tagged: eulerian, fluid-flow, Inlet-boundary-conditions, porous-media
March 12, 2022 at 3:49 pm
d.weragoda
SubscriberHi
I'm also trying to model the Capillary rise in porous media. I've merely used a 2D model and the Corey model along with Leverette J-Function. Is there any document available online that I can have a look at to understand how the Corey model is used along with Brooks-Corey, van-genuchten and Leverette J-functions defining capillary pressure. I'm a bit confused as to how the inlet condition should be set if I am to determine the rise of water in a porous structure, cause eventually the capillary pressure and the hydrostatic pressure of the liquid column has to be balanced when the maximum rise is reached. Would appreciate some thoughts on this. Thank you.
March 14, 2022 at 12:11 pmDrAmine
Ansys EmployeeThe best document here is to consult the Official Only Ansys Fluent Help. Wherever you are in Fluent "Hit F1" and you will redirected to the Help page.
2630
2104
1327
1110
461
