March 19, 2021 at 11:01 am
RajasekarK123
SubscriberI need to spray liquid in the spray chamber at different timings like 0 to 10s, 30 to 40s, 50 to 60s. is it possible to define such injectionn -
March 19, 2021 at 11:48 pm
Surya Deb
Ansys EmployeeHello, nYou can define multiple injections with the exact same properties but different start and stop times. nFor the 2nd injection, use start time as 0 s and stop time as 10 s...For the 2nd injection, use start as 30 s and stop as 40 s, etc. nYou could also make use of file injection and Execute Command options to read in the injection file during these intervals.nRegards,nSDn -
March 20, 2021 at 4:34 pm
RajasekarK123
SubscriberI tried with different injections with different injection timings but the first injection only injects the spray for the set period, other injections not injecting any at their specified flow timingsnn -
March 23, 2021 at 4:07 pm
Surya Deb
Ansys EmployeeCheck your mass flow rates. Are they the same for all the injections? Also, are the injected particles being tracked properly?n -
March 23, 2021 at 4:14 pm
RajasekarK123
SubscriberI have same mass flow rates for all the injections and particles also tracked properlyn -
March 24, 2021 at 12:05 pm
Ansys EmployeeAre the other injection properties (position etc) the same? Each injection will have a different ID so what happens if you plot injection:2 (or whatever it's called) when it should be active?n -
March 24, 2021 at 12:25 pm
RajasekarK123
SubscriberYes all the injections are defined at same coordinate, other than injection 1 no other other injections are spraying liquid. when i plotted mass flow rate of liquid at outlet the curve has some value only for the first injection flow period and stops at the end of injection 1 then the curve reaches 0 kg/s. no other injections are starting even their specified flow time exceeds.n
Viewing 6 reply threads
Trending discussions
Top Contributors
2614
2088
1321
1108
459
Top Rated Tags
