August 21, 2023 at 8:31 pm
Ashwini Kumar
Ansys EmployeeGenerally speaking, the license information should be entered during the VM creation.
If this is not done, you need to point to the correct IP address to use the Ansys application.
Windows: Start -> Ansys 2023R1 -> Ansys License Settings 2023 R1
Linux:
On the command prompt, navigate to /NFS_Storage/ansys_inc/shared_files/licensing
in order to edit ansyslmd.ini, you need to know the SSH password. See the instructions on how to get SSH
You can edit the ansyslmd.ini and save it.
- (0x8007052E): The user name or password is incorrect
- Some of the instance types are greyed out and cannot be selected.
- Ansys Gateway powered by AWS – Minimum Technical Skills
- ADConnector Installation Fails due to .NET
- Welcome to Ansys Gateway powered by AWS
- Unable to install Service.
- Ansys Gateway powered by AWS – Express Setup Overview and Prerequisites
- About Multi-domain support
- What is the average time to set an HPC cluster up?
- How does metering work?
7742
4504
2971
1449
1322
