Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
How to set lump port with imaginary part in Ansys HFSS
    • Ian Lin
      Hello,I have some question. I want to set lump port with imaginary part in Ansys HFSS.
      I tried to set impedence with imaginary part but the S-parameters and Smith chart are unreasonable.
      What parameters do I need to set so that I can get the correct S-parameters and Smith chart.
      Thanks.
    • Praneeth
      Hi Ian,
      Thank you for reaching out and your patience is much appreciated.
      Please go through these links of the online HFSS help documents and see if you have set up in the same way - Ansys Electronics 2023 R1 - Assign Lumped Ports for Modal Solutions and Ansys Electronics 2023 R1 - Assign Lumped Ports for Terminal Solutions.
      Best regards,
      Praneeth.
