How to set minimum and maximum values for default legend viewer
    • e19m5714
      Greetings to you. I am doing mixing analysis in the fluent solver. The analysis is based on two cases which I have to compare them. I wanted to set the range of velocity magnitude on the default legend viewer so that the two cases can be compared in one default legend viewer. This is an example of what I am trying to say below. two figures analysed in a single legend. I will appreciate your ideas. Thanks for cooperation.
      Mixing pattern in two reactors
    • Keyur Kanade
      deselect auto range on left side and then you can give manual values for range.
      Keyur
