March 24, 2021 at 12:06 am
Pulsar123
SubscriberDear all,nI'm not sure if this question is better suited in the materials forum, but I am trying to model a realistic bullet impact simulation in explicit dynamics. I have successfully run the simulation several times on various surfaces. I have used Johnson-Cook parameters and specified material properties. However, I am not sure if Ansys automatically accounts for kinematic strengthening and other stress/strain effects on the materials. Any insights would be appreciated as to how much information I am required to input to maximise accuracy of the damage and plasticity models.n(Note: I do not have any self-conducted experimental data to make a comparison to).nThank you.n -
March 25, 2021 at 4:38 pm
Chris Quan
Ansys EmployeeIn Explicit Dynamics system, once simulation is done, you can highlight the Solution in Tree Outline and then click on Worksheet on the top toolbar to open the window of User-Defined Results. nAmong these results, you can plot YLD_STRESS to watch the change of current yield stress with plastic strain (strain hardening), plastic strain rate (strain rate hardening), and local temperature (thermal softening).nYou can also plot EPS_RATE for Effective Plastic Strain Rate or other stress/strain components to monitor their change in time and in space.n -
March 25, 2021 at 6:34 pm
Pulsar123
SubscriberThank you.n
Trending discussions
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
Top Contributors
2656
2120
1347
1118
461
Top Rated Tags
