July 23, 2019 at 5:00 pm
hquoc87
SubscriberHello everyone,
I'm new to Ansys and I'm using Ansys Workbench to simulate the effect of traffic load to the buried pipe. I wanted to calculate the pipe's probability of failure under the effect of the traffic load. I used the deformation as the performance. Technically, the pipe is considered as failed when its deformation value exceeds 5% of the pipe diameter. However, I couldn't find anywhere to set the failure criteria based on the deformation parameter or either the range for deformation (so that in the CDF plot, it can show the probability of deformation value from 0 to the threshold of deformation which is 2.7in in my case). The only thing that I could see was the calculated value of deformation. Can anyone please help me with this? Any information helps.
Thank you so much!
Hung.
July 24, 2019 at 2:28 pm
SubscriberIf you Attach a .wbpz Archive file to your post, it makes it easier to investigate an answer to your question.
July 24, 2019 at 3:12 pm
hquoc87
SubscriberHi Peter,
I just attached a .wbpz file. Thank you for your help.
Hung.
July 24, 2019 at 8:32 pm
SubscriberAlso say which Release of ANSYS you are using.
July 25, 2019 at 12:25 am
hquoc87
SubscriberI'm using Ansys 2019R1
Best,
Hung.
July 26, 2019 at 3:15 pm
SubscriberI looked at your model. You need to improve the mesh before you do a lot of work on this model. You have a thin layer on top called AC, and an even thinner set of blocks on top of that layer to apply loads to.
Apply a Multizon mesh method and you can get Hex elements.
But do you even need to thin blocks? Why don't you just create faces on the AC layer and have no thin block on top?
The subgrade around the pipe and the Base has a very coarse mesh. I would reduce the element size on that also.
You want the elements on either side of the contact to have similar sizes. This pipe has a much finer mesh.
July 26, 2019 at 8:13 pm
SubscriberAnother problem with your Parametric model is when you change the diameter of the pipe, you don't also change the diameter of the hole in the Subgrade.
Since there is bonded contact between the pipe OD and the hole, maybe you can get away with this, but it is a mistake in your model that you should correct.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2616
2098
1323
1108
461
