How to set the fixed axial in the Workbench?
    • Nguyen Van Toan
      Hello everyone!
      I have a cylinder here. How can I fix only its axial ( in the x direction)?
      Thank you so much!
    • peteroznewman
      A body has six degrees of freedom, when you say fix only axial (X-direction) do you mean that you also want to fix rotations about Y and Z?
      One way to to that is to pick a face and apply a Remote Displacement. That will show all six degrees of freedom and you can type a 0 in any DOF that you want fixed.
    • Aniket
      I see that you have rejected answer from. Can you please explain why his response does not answer your question?
      -Aniket
