How to set time step for a liquid-gas VOF with dynamic mesh
    • Hoss
      In this axisymmetric domain, to squeeze the liquid bridge between two walls, a sinusoidal motion was defined for the left wall as a "Rigid Body" via a UDF.
      While the period of the wall motion is ~6 sec in the UDF, the variable timestep based on a courant number of 0.25 is in the order of 1e-8 which makes the solution extremely long. A larger fixed TS will result in divergence. How should I set the TS reasonably?
      Thank you!
Viewing 0 reply threads
