September 12, 2023 at 6:28 pm
Zhizhong Yan
SubscriberI tried to use default settings, but Zemax Does not run at all.
-------------------------------------------- NORMAL STARTUP 2023/09/12 12:41:07 ---------------------------------------------Ansys Licensing Interconnect version 2023.2.0 (20230523) for winx64. Updated at Ansys Release 2023 R2. Started on 2023/09/12 12:41:07 by Zhizhong@DESKTOP-HTEIL2O:winx64 with pid 9140.(C) 2023 ANSYS, Inc. Unauthorized use, distribution, or duplication is prohibited.Built Using FlexNet Publisher v11.16.4.0 build 252457 x64_n6Built Using OpenSSL 1.1.1t 7 Feb 2023-----------------------------------------------------------------------------------------------------------------------------Please note that entries in this debug log have the following format:TIMESTAMP ACTION FEATURE REVISION (BUILD DATE) A/B/C/D W/X/Y/Z PID:MPID:APP:USER@HOST:PLATFORM:DISPLAY SOCKET:IPLicenses statistics:--------------------A is the number of licenses requested by this ACTION.B is the number of licenses used by this USER.C is the number of licenses used by all users.D is the number of licenses available in the local license pool.License server performance statistics:--------------------------------------W is the number of currently connected client applications.X is the maximum number of connected client applications.Y is the unique serial number of this client application.Z is the number of all client applications served by this Licensing Interconnect server.-----------------------------------------------------------------------------------------------------------------------------2023/09/12 12:41:07 INFO ANSYSLI_CMD=C:\Program Files\Ansys Zemax OpticStudio 2023 R2.01\licensingclient\winx64\ansyscl.exe -acl DESKTOP-HTEIL2O_Zhizhong -nodaemon -log C:\Users\Zhizhong\AppData\Local\Temp\.ansys\ansyscl.DESKTOP-HTEIL2O.DESKTOP-HTEIL2O_Zhizhong.log2023/09/12 12:41:07 INFO ANSYSLI_INITIALIZATION_FILE=No initialization file found.2023/09/12 12:41:07 INFO ANSYSLI_PRODORD_FILE=COULD NOT BE FOUND!2023/09/12 12:41:07 INFO ANSYSLI_TIMEOUT_FLEXLM=152023/09/12 12:41:07 INFO Configuring ACL Core2023/09/12 12:41:07 INFO ACL Core Initialized2023/09/12 12:41:07 INFO ANSYSCL_PORT=631732023/09/12 12:41:07 INFO Listen Socket Created2023/09/12 12:41:07 INFO ANSYSLI_CLIENT_IDLE_TIMEOUT=302023/09/12 12:41:07 INFO ANSYSCL_FNP_PATH=1055@localhost2023/09/12 12:41:07 INFO Ready to accept connections.2023/09/12 12:41:08 INFO ANSYSLI_IP_OVERRIDE option is off.2023/09/12 12:41:12 CLIENT_ACCEPT 1/1/1/1 6940:127.0.0.12023/09/12 12:41:12 CLIENT_CONNECT 1/1/1/1 12940:12940:ANSYS OPTICSTUDIO:Zhizhong@DESKTOP-HTEIL2O:winx64 6940:127.0.0.12023/09/12 12:41:12 INFO Shared features for User/Host/Display context with id DESKTOP-HTEIL2O_Zhizhong:-1 zos_level1 -1 zos_level2 -1 zos_level32023/09/12 12:41:12 NOTICE User/Host/Display context created with id DESKTOP-HTEIL2O_Zhizhong. 1/1/1/1 12940:12940:ANSYS OPTICSTUDIO:Zhizhong@DESKTOP-HTEIL2O:winx642023/09/12 12:41:16 INFO Unable to connect to FLEXlm path 1055@localhost; adding to "Unavailable FLEXlm Servers" cache.2023/09/12 12:41:21 DENIED zos_level2 23.2 (2023.0505) 1/0/0/0 1/1/1/1 12940:12940:ANSYS OPTICSTUDIO:Zhizhong@DESKTOP-HTEIL2O:winx64 6940:127.0.0.1Request name zos_level2 does not exist in the licensing pool.Cannot connect to license server system.The license server manager (lmgrd) has not been started yet,the wrong port@host or license file is being used, or theport or hostname in the license file has been changed.Feature: zos_level2Server name: 127.0.0.1License path: 1055@localhost;FlexNet Licensing error:-15,10. System Error: 10061 "WinSock: Connection refused" -
September 13, 2023 at 10:30 pm
Lito Yap
Ansys EmployeeI believe this is a duplicate to post, Zemax can’t start (ansys.com), which has been resolved. Kindly mark both posts as answered/resolved. Thank you!
- how to export results from SPEOS to Mechanical
- Negative Reflection Problem
- Simple Optical simulation
- Ansys SPEOS- Diffusion Coefficient of a fluorescence
- Ambient source on Ansys SPEOS
- Purcell Factor on Dielctric Mirror
- Light reflection on a XMP map
- HUD simulation Speos
- How I can get a student version of Ansys Speos Software to learn?
- Ansys SPEOS-Fluorescent Material
7592
4440
2953
1427
1322
