How to setup the Time step animation correctly?
    • José Mantovani
      Hello everyone!
      I calculate a transient flow and I get 200s of flow.
      I create a animation video type time step of this flow, choosen the first to last step (all time steps), but the video have just 5s. Why? What can I have gone wrong? I using the CFD Post...
      Thanks all!
    • Vishal Ganore
      Have you loaded all the transient solution data files under CFD post? How many time steps do you see under time-step selector?
    • raul.raghav
      Mantovani, please refer to the following screenshot if you're using Timestep Animation
      If you're using Keyframe Animation (the default setting is 24 fps), please refer to the following post:
      Keyframe Animation
    • José Mantovani
      Hello Rahul and Vishal, thanks for the greatful help!
      So Rahul, I open again the CFD Post and I used the setting as control by Timestep. Now I use in the same way of screenshot above and set control by time. I stay waiting some minutes for it's run and I see what I get.
      Thanks one more time!
      Mantovani.
    • José Mantovani
      So, Now I get the video with the set in the same way of Rahul's screenshot, but equal before the video just have 5s.
      Below a image of maybe a solution, I have a doubt... And a contour in a sometime of my simulation, ploting vorticity.
      For this, I used a steady state first with SST k-omega and second LES model.
      Thanks!
      Mantovani.
    • raul.raghav
      Mantovani, sorry for the late reply. The attached screenshot would definitely work. CFD-Post has a default setting of 24fps. Rest should be pretty much self-explanatory.
    • José Mantovani
      Thanks Rahul, I will try do this! I warning you, if it works.
Viewing 6 reply threads
