February 3, 2022 at 4:47 pm
zgao04
SubscriberI am doing a solid/fluid conjugate heat transfer simulation. I defined a temperature dependent heat conductivity for the solid material using expression. I want to check if the definition is correct, so how to show/plot the thermal conductivity value in solid domain? Can somebody tell me how to do that?
Thanks,
Gao
February 4, 2022 at 1:13 pmNikhil Narale
Ansys EmployeeHello,
You can use contours to check the thermal conductivity variation. In contours, select contours of 'Properties' and select 'Thermal conductivity' from the drop down menu. Select the surface of interest and click on compute and display.
Hope this helps.
Nikhil
February 4, 2022 at 2:46 pmzgao04
SubscriberNikhil Yes, it seems working. But why there is no expression for me to choose? because the user's guide (I am referring to Fluent 2021R1 user's guide, chapter 5, section 5.3.5. Postprocessing Expressions ) says I can choose expression for the contour plot.
Thanks Zhaosheng
3778
2573
1825
1242
598
