May 5, 2022 at 12:35 pm
shawn_choi
SubscriberI am try to investigate a small ball movement inside a big shell which is floating on the sea. The floating shell is moored by linear cable. Since the small ball inside the shell is absolutely outside the water. I think it’s difficult to simulate by aqua. So I model only the big shell and obtain its motion under cable. Next, I want to transfer the motion data of shell into Rigid Dynamic and calculate the motion of small ball inside the shell. Is it a reasonable solution of my problem???
May 5, 2022 at 2:43 pmshawn_choi
SubscriberIn fact I try to use remote displacement simulating the movement of shell excited by ocean wave. But I canÔÇÖt find a way to import the csv data in Rigid Dynamic
May 6, 2022 at 9:48 amAshish Khemka
Forum Moderator
You can perform a transient structural simulation. Set the behavior of bodies to be flexible.
Regards Ashish Khemka
- A solver pivot warning or error has been detected
8762
4658
3151
1678
1456
