How to simulate a rubber material in modal analysis
    • Peter Jonson
      Hello.
      I have a vertical electric motor which rotates at 25 Hz. The motor's  natural frequency is 25 Hz too. I want to simulate a rubber material with additional weight on the top of the motor like vibration damper. I don't know what exactly rubber I will use. Just wanna see if any changes in damping will occur.
      I know that there are some rubbers material in workbench i can use.
      My question is should I set up a damping coefficient for these rubbers ?
      I am also wondering maybe someone already performing similar simulation and I would be very interested to get a link.
      Thanks in advance.
      Peter.
    • Erik Kostson
      Hi
      Never seen an analysis of exactly this situation.
      You could add damping as that will represent reality the best , but one would need to measure the damping or if it is known from the manufacturer (if they have measured it), etc. Damping is always hard to know I think in dynamic analysis especially for non-metallic material.
      All the best
