September 15, 2018 at 4:26 am
Nuno koh
SubscriberHello~
I'm beginner of ANSYS APDL.
I'm interested in contact stress.
I have been trying for it with the text "ENGINEERING ANALYSIS with ANSYS SOFTWARE (Author: Y. Nakasone and S. Yoshimoto)".
The Contact stress problem is described in 120page ~138page in the text.
I have followed the text, But I can't get the solution.
What is wrong ?
I have added the capture image for the contact stress problem from the text.
Plz, refer to the link below for details.
https://drive.google.com/file/d/16KlDF9rfwiavOuHUf8gOBvPjTIbJ4Nb6/view?usp=sharing
Thanks.
September 15, 2018 at 7:49 pm
SubscriberNuno koh,
Below I put an image of the textbook problem you had in your link for ease of viewing by the community.
Please reply with the full APDL code you used. Click the Blockquote button before you paste to keep the length to a minimum. Note that there is a 3000 character limit to each post.
I hope you get a reply from someone who uses APDL code, because I use Workbench and Mechanical to solve Static Structural models.
September 16, 2018 at 2:44 pm
Nuno koh
SubscriberPlz, refer to the link below with source code
https://drive.google.com/file/d/1mdRnHIxMYPpS_o5oCdPq5f_w6h13CSvv/view?usp=sharing
September 16, 2018 at 2:46 pm
Nuno koh
Subscriber/PREP7
BLC4,0,0,500,-500
CYL4,0,500,500,-90,500,0
SAVE
SAVE
FLST,2,2,5,ORDE,2
FITEM,2,1
FITEM,2,-2
AGLUE,P51X
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,2.1E5
MPDATA,PRXY,1,,0.3
ET,1,PLANE183
KEYOPT,1,1,0
KEYOPT,1,3,2
KEYOPT,1,6,0
ET,2,TARGE169
ET,3,CONTA172
FLST,5,2,4,ORDE,2
FITEM,5,2
FITEM,5,-3
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,60,1/10, , , ,1
FLST,5,2,4,ORDE,2
FITEM,5,1
FITEM,5,4
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,60,10, , , ,1
FLST,5,2,4,ORDE,2
FITEM,5,8
FITEM,5,-9
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,40,10, , , ,1
FLST,5,1,4,ORDE,1
FITEM,5,6
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,40,1/10, , , ,1
MSHKEY,0
FLST,5,2,5,ORDE,2
FITEM,5,1
FITEM,5,3
CM,_Y,AREA
ASEL, , , ,P51X
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
!!!!!!!!!! Cylinder btm surface line selection/!!!!!!!!!!
LSEL,S, , , 8
!!!!!!!!!! /Cylinder btm surface line selection!!!!!!!!!!
!!!!!!!!!! Cylinder btm surface node selection/!!!!!!!!!!
NSLL,R,1
!!!!!!!!!! / Cylinder btm surface node selection!!!!!!!!!!
!!!!!!!!!! Cylinder Btm surface contact point near area selection/!!!!!!!!!!
FLST,5,14,1,ORDE,3
FITEM,5,242
FITEM,5,11043
FITEM,5,-11055
NSEL,R, , ,P51X
!!!!!!!!!! /Cylinder Btm surface contact point near area selection/!!!!!!!!!!
!!!!!!!!!! Contact element define of cylinder btm surface /!!!!!!!!!!!!!
TYPE, 3
MAT, 1
REAL,
ESYS, 0
SECNUM,
TSHAP,LINE
!!!!!!!!!! /Contact element define of cylinder btm surface !!!!!!!!!!!!!
save
!!!!!!!!!! Contact element attach on cylinder btm surface /!!!!!!!!!!!!!
FLST,5,14,1,ORDE,3
FITEM,5,242
FITEM,5,11043
FITEM,5,-11055
CM,_Y,NODE
NSEL, , , ,P51X
CM,_Y1,NODE
CMSEL,S,_Y
CMSEL,,_Y1
ESURF, ,BOT,
CMSEL,,_Y
CMDELE,_Y
CMDELE,_Y1
!!!!!!!!!! /Contact element attach on cylinder btm surface !!!!!!!!!!!!!
save
ALLSEL,ALL
!!!!!!!!!! Flat plate Top surface line selection/!!!!!!!!!!
LSEL,S, , , 3
!!!!!!!!!! /Flat plate Top surface line selection!!!!!!!!!!
!!!!!!!!!! Flat plate Top surface node selection/!!!!!!!!!!
NSLL,R,1
!!!!!!!!!! /Flat plate Top surface node selection!!!!!!!!!!
!!!!!!!!!! Flat plate Top surface contact point near area selection/!!!!!!!!!!
FLST,5,23,1,ORDE,3
FITEM,5,242
FITEM,5,340
FITEM,5,-361
NSEL,R, , ,P51X
!!!!!!!!!! /Flat plate Top surface contact point near area selection!!!!!!!!!!
!!!!!!!!!! Target element define on Flat plate Top surface/!!!!!!!!!!!!!
TYPE, 2
MAT, 1
AuthorPosts-->Viewing 3 reply threads- You must be logged in to reply to this topic.
2706
2142
1355
1144
462
