How to simulate Heat transfer and Mass transfer in dehumidifier?
    • Parthj
      Here moist air is flowing between the desiccant and only moisture is absorbed by desiccant in membrane. Membrane is such that air can't flow into desiccant and only moisture is allowed. Image is attached for the reference. So how to simulate the system?
    • YasserSelima
      There are many posts on using UDF to define mass transfer through membrane ... nI think might help you in this.n
    • Abbasraza20000220
      Thanks a lot. for your support.nRegards,nAbbas Razan
