February 19, 2022 at 12:02 pm
Md_Salem
Subscriberhow to simulate the extraction of electromechanical impedance of piezoelectric patch over a certain frequency period in harmonic analysis using ANSYS 21R2 workbench ?
February 20, 2022 at 7:01 pmMd_Salem
SubscriberI simulated free PZT plate on workbench and done the modal analysis, when I try to do the harmonic analysis for this free PZT plate, the workbench asks about the structural constraints despite I defined the damping. while I can do it in the APDL without any problems.
April 5, 2022 at 7:43 pmMd_Salem
Subscriberto continue simulation with free PZT
write the orders of run in APDL command in the workbench
Trending discussions- 2022 R1 What’s New PDF/PPTX?
- Prms/ pmean
- separation based debonding,CZM parameters
- Hydrodynamic diffraction and response
- The simulated results of microstrip patch antenna does not match the online example
- Desktop/laptop specification for Ansys forte
- how to simulate piezoelectric patch on ANSYS workbench ?
- Heat simulation – change source wavelength
- Meshing/Simulation problem
- Mudjere
2752
2156
1365
1150
462
