November 27, 2019 at 1:27 pm
Alex1EDP
SubscriberHello,
I am trying to simulate the construction phase of a concrete dam, meaning I have the geometry and mesh generated and divide into three phases of concreting.
I would like to run the self-weight analysis divided into three steps:
1. self-weight applied to the first third of the dam;
2. adding the second construction phase on top of the prior step and results;
3. adding the final phase of construction on top of the second phase.
Is this possible?
November 27, 2019 at 4:14 pm
November 27, 2019 at 4:16 pm
Alex1EDP
SubscriberThank you very much for your reply.
I am trying to use that method but it takes a long time to run the simulation.
November 27, 2019 at 6:42 pm
SubscriberSome of my simulations run for tens of hours.
November 29, 2019 at 12:45 pm
Alex1EDP
SubscriberHi thank you very much for your help.
I have solved my problem but now i am facing another one.
I am trying to perform a transient thermal analysis of the dam, meaning the temperatures vary over time and i am usaing the an apdl code but i keep getting the same error:
*** WARNING *** CP = 1.328 TIME= 12:43
7
There are no active degrees of freedom.
*** ERROR *** CP = 1.375 TIME= 12:43
7
An unexpected error ( SIG$SEGV ) has occurred... ANSYS internal data
has been corrupted. ANSYS is unable to recover and will terminate.
Previously saved files are unaffected. Please send the data leading
to this operation to your technical support provider, as this will
allow ANSYS, Inc to improve the program.
3251
2443
