how to simulate the cooling of a heated source object using air at 25c by using fluent?
    • Aayush
      i am a team member participating in sae baja india,i m currently working on a system to cool the cvt casing using axial fan mounted on the primary pulley.i want to simulate the outlet temperature from my cvt casing where booth the sheeves serve as a heat source. i m not able to find a relevent video on youtube for doing this simulation. please help!!!!!
    • DrAmine
      Do you have picture of your geometry?
    • Aayush
      thank you sir!!!
      this material turned to be useful for me
    • DrAmine
      Mark as is solved so that other might take advantage of it.
Viewing 3 reply threads
