September 4, 2023 at 6:56 am
Jian Liu
SubscriberHello everyone, I am using FLUENT software to do numerical simulations of metal dissimilar welding and I am experiencing some difficulties.
- If I use VOF to build the model, can I set only two phases (upper gas domain, lower layer stacked with two layers of metal)?
- If a gas-liquid two-phase flow is used, how are the two metal materials below the gas domain set?
- Previously, I had simulated the melting of a single layer of metal (setting gas and metal materials), and after initialization, I used the "patch" function to customize the area size of the second phase (i.e. metal phase), when the matrix contains two metal materials, how do I make the two phases one?
- I would be grateful for any recovery! Thanks again!
September 11, 2023 at 2:05 pm
Ansys EmployeeIf the solid & melt are the same material have a look at the solidification & melting model in Fluent. With VOF you can have lots of different phases, I'm fairly sure there is a limit but would be very surprised if anyone ever reached it!
7818
4514
2979
1453
1322
