October 23, 2018 at 5:26 am
vkumarsingh388
SubscriberHi,
I have generated a honeycomb structure using honeycomb creator in design modeller, but the geometry generated is bigger in size then i have requested for, so i have to slice it to required dimension but i don't know how to do it in DM, i have tried it but it doesn't result in anything.
I have made a plane at required distance and uses slice feature but nothing happened.
please help me.
October 23, 2018 at 6:53 am
Keyur Kanade
Ansys EmployeeHi,
Following video may help you.
Also, please like the answers which have helped you move forward and in the end, once your issue is resolved, please mark the most appropriate solution (most useful advice) as 'Is Solution'. This will help others who are using this thread to find answers to similar questions.
Keyur
October 24, 2018 at 4:59 am
Keyur Kanade
Ansys EmployeeIs your issue resolved?
If so, can you mark it as resolved so that it will help others on forum.
Keyur
October 27, 2018 at 4:08 pm
vkumarsingh388
SubscriberHey My bodies consist of surfaces because i have generated it by using honeycomb generator, and i have tried to remove the extra portion that i have get from creator, can you please suggest me how to remove remaining material. -
October 27, 2018 at 5:39 pm
SubscriberIn DesignModeler, Slice will cut surface bodies. You must create a New Plane that has the XY axis as the cut plane.
October 28, 2018 at 5:10 am
vkumarsingh388
I have generated honeycomb structure using creator and I required structure length of 200 mm but the creator has generated structure of length 204.6 mm so, I have to make it 200 mm, for that I have created a plane at 4.6 mm from one side and try to slice it but nothing happens, can anyone please suggest me how to reduce it to required size.
Thanks you in advance.
October 29, 2018 at 6:03 am
Keyur Kanade
Ansys EmployeePlease create a solid body out of surfaces. You can use Create - body operations - sew command.
Then use slice operation.
Keyur
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2706
2146
1357
1144
462
