TAGGED: cleanup-connections, export, geometry, hfss, layout
April 13, 2022 at 5:24 pm
dwightb
SubscriberAfter exporting a physical circuit from the Filter Design Wizard in HFSS the geometry in the Layout Editor is not connected according to the schematic as shown below.
April 27, 2022 at 11:56 amPraneeth
May I know which version of AEDT are you using?
The Filter design wizard is very old.
Please update to the latest version and I would recommend you to use "Filter Solution" pack which is more advanced.
All the very best Praneeth.
August 13, 2022 at 8:54 pmdwightb
SubscriberViewing 2 reply threads- The topic ‘How to snap geometry in layout’ is closed to new replies.
Trending discussions- Applying rotor skew
- Effect of region on force calculation
- How to make the available GPU on my Desktop to be used for direct solver simulations in ANSYS HFSS ?
- Parasolid entity check failed for part
- HFSS Parasolid Error
- Induction Heating Simulation
- Co-simulation between HFSS and structural/workbench
- IBIS AMI models
- Radial and Tangential force
- example files
8808
4658
3151
1680
1470
