how to solve invalid geometry error?
    • Aads99
    • Govindan Nagappan
      Yellow colored field in the details of temperature indicates missing data. In this case, you haven't selected a geometry to apply the temperature. Click on this field(Geometry under Scoping Method) and it will show apply apply and cancel, select the geometry where you want to apply the load and click applynMake sure you see a check mark for temperature before you solve the modelnn
    • grotstein
      I'm trying to solve a complex model and I stubled upon a few Invalid Geometry messages. However, they don't have an association as above (Association is blank) and when I try to right-click and go to object I get the following message.nI did as I am told, but as expected I do not have any filter in the tree enabled. Also the simulation itself runs despite the error messages.nI have defined some Named Selections based on a worksheet selection and also some body-body joints in my model.nDoes anybody have some experience with this problem and any indication how I can solve it?.
