LS Dyna
LS Dyna
Topics relate to LS-DYNA, Autodyn, Explicit STR and more
How to solve mesh artifacts, obtain reaction forces and contact penalty
    • Alexandre Neto
      When using solid elements to mesh each of the 12 layers of composite I am simulating that is subjected to a low-velocity impact, in section view the mesh goes crazy like in the picture. It almost disappears when impacted, but this only happens when using this mesh element. How can I solve this?
      Also, I want to obtain the impact force caused by the impactor to then plot a Force vs Displacement graph. What is the best method? I have tried bndout but it says "file has no information to be found", and spcforc has forces = 0.
      As for the contact, my impactor is visually surpassing the outmost layer. Is there any setting to solve this?
      Thanks!
    • Ram Gopisetti
      I'll talk about the contact penetration problem.
      To decrease pentration, increase contact stiffness.
      cheers, ram
