How to solve Not enough memory error
    • moeenkhurram
      Currently using system with 122 GB ram and I also tired by increasing workspace memory to 40 GB.
    • Sandeep Medikonda
      Try these:
      1. Increase memory in Solver Process Settings. See this discussion (Check Manually Specify Mechanical MAPDL Solver memory settings).
      2. Insufficient memory - You may not have enough virtual memory assigned to your system. To increase the allocation of virtual memory (total paging file size), go to Settings> Control Panel> System (on your Windows Start Menu). Click the Advanced tab and then click Performance Options. Increase the size of your virtual memory.
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v192/wb_sim/ds_While_Starting.html
      3. Turn off distributed solve (in Solve Process Settings>Advanced) and see if it helps.
    • moeenkhurram
      Hi i tired all your mentioned steps still getting same error, I increased ram to 244 GB,also increase virtual memory .
