August 27, 2018 at 11:52 am
August 27, 2018 at 12:52 pm
Keyur Kanade
Ansys EmployeeHi,
The geometry looks corrupt.
Please open geometry in Design Modeler. The use Tools --> Analysis tools --> Fault Detection. Make sure that geometry does not have any errors. If geometry has errors in DM, then please correct them in DM first.
Keyur
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2726
2146
1357
1150
462
