February 1, 2022 at 9:49 am
hanxiangyang
SubscriberFebruary 2, 2022 at 3:23 pmDeyu Li
Ansys Employeeit's a warning about convergence issue. You can use keyword "convergence" to search on Simplorer online help, there is a technote about "Fixing non-convergence in Simplorer" with some suggestions that you can adjust in setting.
- Maxwell, HFSS or Q3D?
- Error
3730
2570
1783
1236
594
