Tagged: #fluent-#ansys, 3d-geomertry, fluent-meshing, hexa-mesh, icem-cfd-mesh
September 6, 2022 at 9:49 am
cez198229
SubscriberI am trying to develop Hexa mesh in a flow domain with a scour hole around the bottom of the cylinder. The flow domain is shown in the figure.
The cylinder and the bottom surface are treated as walls, so the inflation layers must be provided around them.
To provide the inflation layer to the bottom surface with scour hole, first layer thickness, growth rate and the number of layers are provided to the edges 1,2,3,4, 10,11,12 and 13 (as shown in the blocking figure). But the edge properties provided to the edges 1,2,3,4 are getting copied to all the parallel edges (edges 5,6,7,8,9 and the edges in the same row). It leads to the development of inflation layers above the bottom surface in the scour hole region (as shown in the attached figure).
I need the inflation layer only to the bottom surface in the scour hole region but not above it.
Please suggest possible solutions to this problem. -
September 6, 2022 at 10:55 am
Keyur Kanade
Ansys EmployeeWhile defining edge sizing you can click OFF option of Copy to parallel edges.
Please go through help manual for more details
Keyur
September 8, 2022 at 9:22 am
September 8, 2022 at 1:09 pm
Keyur Kanade
Ansys EmployeeNo. of nodes will be same as it is hex mesh. Only thing is you can move vertex to increase edge length.
September 19, 2022 at 4:57 am
cez198229
SubscriberThank you, I solved the issue.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2726
2156
1359
1150
462
