How to specify more constraints such that a surface extrusion can adhere to another surface contour?
April 10, 2022 at 9:51 pm
AndrewZCalSol
Subscriber3) After finishing in ACP Pre, I noticed a few concerns with regards to how the layups were extruded. In the screenshot below taken from Static Structural, one of the parts is extruded (red box showing cross sectional cut) such that one of the sides (yellow line) sticks out of the shell and does not 'ride' along its contour (green line). To be fair, this surface was instructed to be extruded directly downwards (orange arrow) in the Oriented sections section of ACP Pre Setup.
April 14, 2022 at 9:06 pmApril Wang
Ansys EmployeeHi The images you shared cannot be viewed. Without images, I cannot capture the idea for this one.
Could you please update the images?
Thank you so much.
April
April 20, 2022 at 6:12 amAndrewZCalSol
SubscriberThanks for the reply! Here is my attempt to repeat the post with attached images.
Is there a way to specify more constraints such that this part can adhere to the shell's contour on that specified side only?
Trending discussions- ANSYS Workbench Measuring within Design
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2524
2066
1279
1096
457
