February 28, 2017 at 9:45 am
Nikita
Ansys EmployeeHow can I speed up my acoustics analysis without reducing the mesh density and thus accuracy of the results?
July 21, 2017 at 9:35 pm
pgl
Ansys EmployeeGenerally consider two approaches:
1. Optimise the mesh without compromising results accuracy - Easier said than done, but your element sizing is critical and determined by the frequency range you are simulating. Try and refine the mesh primarily in areas of interest, go coarser everywhere else. A general rule of thumb is use a minimum of 12 elements per wavelength for first order elements, less for higher order elements. Here's a good acoustics guide/example from our Channel Partner Simutech.
2. Improve your hardware, choose a higher performance CPU with more cores, up your RAM. Others report a good performance boost by using a GPU.
Here's a video showing how to simulate a lousdspeaker
2616
2098
1323
1108
461
