March 5, 2022 at 9:38 am
denny9696
Subscriberi use ece at simplorer and connect to simulink
the 10 s case must to simulate 10 minutes
how to speed up ?
svpwm is set 10khz
simplify ece model? or some thing can speed up ?
March 11, 2022 at 11:03 pmDeyu Li
Ansys Employee10kHz switching frequency with 10s case, 10 mins sound reasonable to me.
ECE model is a look up table, you can try to switch with just resistors and inductors and see if it speeds up.
You can reach out to Matlab help and see if there is some way to speed up Simulink part.
- Maxwell, HFSS or Q3D?
- Error
2564
2080
1293
1106
459
