February 28, 2017 at 9:13 am
Nikita
Ansys EmployeePlease explain how to split beams in ANSYS SpaceClaim?
September 29, 2017 at 11:55 pm
pgl
Ansys Employee1. Go to Design Tab, Select 'Split Curve' option.
2. Select the beam to be split. It will highlight the beam and its mid-point as well for reference.
3. Click the location on the beam to split.
Voila!
December 10, 2019 at 7:08 pm
Majeed
SubscriberHi Pgl;
can Spaceclaim do this automatically? I mean find all intersections and split them?
I have the same issue but in my case, I have thousands of beams
Many thanks ,,
December 10, 2019 at 8:44 pm
JoePADT
SubscriberYou can do that from the Share function on the Workbench ribbon. You can change the tolerance in the options if needed.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2630
2104
1327
1110
461
