3D Design
3D Design
Topics related to Ansys Discovery and Ansys SpaceClaim.
How to split bodies in spaceclaim
    • as880
      I would like to split this body into multiple bodies that are attached together. I can see the boundaries from this top view, but from bottom all 3 surfaces are flush together so i think ansys thinks of it as a single body. Please outline the exact steps ill need to follow as I am just starting out on ansys. Thank You
    • Rahul Kumbhar
      Hi ArrayYou can use Split tool under Design tab and select the stepped face to split the body.nn
    • Aniket
      ,Can you please post your response to 's solution and why it did not answer your question?n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumn
